Service manual for slushbox replacement
Old Mar 23, 2008 | 09:53 AM
rexmp's Avatar
Default Service manual for slushbox replacement
Hi,
Looks like my daughter's Tib will need the auto replaced soon. Wondering if there's a decent manual or maybe a photo tutorial online describing what's involved.
Fluid is light brown, smells a little burnt, and there are scraping noises coming from the trans. She reports loss of power going uphill. About 80k on the clock.
This doesn't sound like a situation that a fluid and filter will resolve, does it?
Thanks . . .
Old Mar 23, 2008 | 06:43 PM
ken99's Avatar
Default RE: Service manual for slushbox replacement
From http://www.hmaservice.com/:
2003 > G 2.7 V6 DOHC > Automatic Transaxle System
REMOVAL1.Remove the engine cover.[/align]
2.Remove the battery terminal.[/align]
3.Remove the air duct.[/align]
4.Remove the battery tray.[/align]
5.Remove the air cleaner.[/align]
(1)Upper[/align]
(2)Lower[/align]
6.After removing the CKP sensor, O2 sensor and oil pressure switch wiring bracket, separate the connectors.[/align]
7.Remove the speedometer sensor connector.[/align]
8.Remove the transaxle range switch.[/align]
9.Remove the oil cooler hose.[/align]
10.Remove the clip (transaxle side) of the shift cable.[/align]
11.Separate the steering column shaft joint.[/align]
12.Separate the power steering oil pump hose.[/align]
Be careful not to leak after separating.[/align]
13.Separate the hose after removing the clip of the power steering return hose.[/align]
14.Remove the upper connecting transaxle bolt.[/align]
15.Separate the start motor.[/align]
16.Install the engine support fixture.[/align]
17.After removing the tire, remove the caliper.[/align]
18.Remove the transaxle side cover.[/align]
19.Remove the transaxle under cover.[/align]
20.Separate the tie rod end.[/align]
21.Remove the wheel speed sensor and the knuckle mounting bolt.[/align]
22.Drain the oil.[/align]
HUSKERFAN
Jan 22, 2007 01:45 AM
santatrev
Oct 9, 2006 01:07 AM
hurtsantafe
Jul 23, 2006 03:55 PM
hurtsantafe
Jul 23, 2006 03:51 PM
sonnyboy
Feb 28, 2006 06:35 PM
