Shifter Knob Removal
I just purchased a 2001 automatic Tiburon. The shifter plate had some nasty scratches, therfore I am changing it. How do I remove the shifter knob (automatic)to slide in the new plate?
RE: Shifter Knob Removal
A picture paints a thousand words:
http://www.hmaservice.com/data/Passe.../ekda029a2.gif 2001 > G 2.0 DOHC > Transaxle/Transmission REMOVAL a. Remove the console box assembly.[/align] b. Remove the knob installation screws.[/align] c. Disconnect the overdrive switch connector, remove the 3 connector pins from connector with small driver, and then remove selector knob assembly.[/align] http://www.hmaservice.com/data/Passe.../ekda030a2.gif d. Disconnect the position indicator light connector.[/align] e. Remove the shift lever indicator assembly.[/align] http://www.hmaservice.com/data/Passe.../ekda030b2.gif |
