Hyundai Trajet This is Hyundai's reply to the popular American mini-van market.
Dashboard lights
Old Feb 14, 2022 | 08:24 AM
Dooner's Avatar
Default Dashboard lights
Hello,while changing the bulb in the glove compartment i think i blew the fuse for the dashboard lights on my 07 Hyundai trajet. Anyone know which fuse to change to see if this is the problem?
Old Feb 14, 2022 | 10:15 AM
Because all Hyundais are not the same, the fuse may be in a different position on the fuse panel. May or may not say "dash lamps"
Suggest you check with your owner's manual in the "Specifications", section and it will show you the fuse and describe what it protects.
Old Feb 15, 2022 | 04:39 AM
Dooner's Avatar
Suggest you check with your owner's manual in the "Specifications", section and it will show you the fuse and describe what it protects.[/QUOTE]
Thank you Hanky, found a diagram online as to fuse layout and am back with full lights again.
Old Feb 16, 2022 | 07:45 AM
Thank You for the update.
jrhod03
Feb 5, 2021 06:48 PM
iggy_pop
Sep 11, 2014 08:55 AM
llomo000
May 14, 2013 10:03 PM
hopalongk5
Aug 20, 2012 01:47 PM
bchgoer
Jan 25, 2011 08:37 PM
