2008 P0733 and P0734 codes
Old Dec 17, 2023 | 10:43 PM
rhensonsr's Avatar
Default 2008 P0733 and P0734 codes
Just bought this truck and the transmission is only going into 1st and 2nd gear. CEL is on and 733 and 734 codes are in the TCM. I plan on changing the fluid. As I understand, the filter is inside the tranny and since I am not able to remove the tranny, the filter will not get changed. Is there anything else to check/replace? Thanks!
Old Dec 18, 2023 | 10:10 AM
You would require a capable scan tool to do some further checking of things like speed sensors, solenoids in trans not working ..
What you can do is check all wiring connections to the trans . Many times a poor connection involving signals from the trans to controls can produce all kinds 0f problems.
Checking them means unplugging them and look for any corrosion or loose pins.
Old Dec 18, 2023 | 04:04 PM
rhensonsr's Avatar
Default Thanks!
That is something I will try tonight when I get home.
Old Dec 20, 2023 | 05:56 PM
rhensonsr's Avatar
Pulled and inspected the plugs and all are good. There is not a bottom pan but found a drain plug. Is the pan facing the front of the vehicle?
alydar66
Jul 5, 2021 11:24 PM
noeffort
Feb 29, 2020 02:50 PM
breeon68
Dec 21, 2013 07:06 AM
cmavour
May 12, 2011 11:05 AM
hatda02
Sep 8, 2007 09:13 AM
