2017 Tucson won't start after ignition assembly replacement
Old Aug 30, 2022 | 08:43 PM
Manuelgiron4's Avatar
Default 2017 Tucson won't start after ignition assembly replacement
Hello all,
I purchased a car that had been vandalized, completely destroyed the ignition switch and part of the opening in the ignition assembly. I went ahead, ordered an ignition assembly from the junkyard and swapped it out - got the respective keys to the assembly. So when I turn the key to ON, everything inside turns on, the AC works, the windows work, the lights work, everything electric seems to work. However, when I turn the key further to invoke the starter/engine, nothing happens. I do hear a small click, like if the solenoid on the started is moving to make contact, but the car does nothing. It doesn't crank, doesn't make any noises or noticeable attempts at turning on besides that small click I just mentioned. I am thinking that it could be the key, as it's not registered to the car, but I will admit that I am coming from a place of ignorance so I would appreciate any and all guidance here. I would also like to point out that the security system seems to be working just fine and the dashboard is not showing any errors related to the immobilizer or the key. Thank you in advance for any and all help!
-Manuel Giron
Old Aug 31, 2022 | 07:02 AM
Your original keys were coded to your vehicle.
If, you changed to a different key , the security system will not recognize the new key until it is reprogrammed. Is this what you did?
Old Aug 31, 2022 | 10:34 AM
Yeah that's what I did, the new ignition assembly came with new keys. How do I go about reprogramming the keys?
Old Aug 31, 2022 | 03:34 PM
You have 3 choices,
Dealership- $$$$$
Certified locksmith -$$$-?
Shop with security clearance and equip to reprogram-$$$-??
They would need,
Proof of ownership
Old key to read
At least 2 programmable new keys..
The keys have to be programmed to your particular vehicle.
tgawron
Aug 4, 2018 07:29 AM
jimmy70
Dec 22, 2016 10:04 PM
sunnykita
Nov 15, 2010 07:18 PM
ronnieg16
Jan 5, 2010 05:36 PM
gvsuman
Aug 22, 2007 07:25 AM
