-   Hyundai Tucson (https://www.hyundaiforum.com/forum/hyundai-tucson-24/)
-   -   Panic Alarm goes off when I lock the car. 2007 Hyundai Tucson. (https://www.hyundaiforum.com/forum/hyundai-tucson-24/panic-alarm-goes-off-when-i-lock-car-2007-hyundai-tucson-12532/)
PSUGUNNER Apr 13, 2012 11:50 AM
I have a 2007 Hyundai Tucson. When I lock the car, my panic alarm goes off. It does not happen right away, but even if it waits an hour, it will eventually go off. I have used the FOB to lock the car, I have locked it from the inside using the automatic locks, and I have even used the key inserted into the door to unlock and then lock the doors. Nothing I have tried prevents the panic alarm from going off. I have replaced the battery in the FOBs, tried using my spare key, and even replaced the car battery. At this point I do not lock my car, and I am willing to try ANYTHING!!! Any help you can provide would be great. Thank You.
NovaResource Apr 13, 2012 03:35 PM
One of the door/hood/tailgate sensors are bad or misaligned. Check the hood first as that's usually the problem. Make sure the hood and all doors are closed all the way.
PSUGUNNER Apr 13, 2012 03:39 PM
Thank you for the suggestion. I will definitely look at the sensors. What do the sensors look like? Do you know where they would be located? Is there a way to test the sensors, or should I just replace them?
elkarshofy Apr 14, 2012 12:57 PM
1 Attachment(s)
It could possibly be a faulty door latch. The electronics inside the switch can go bad and cause the alarm to go off at "inappropriate" times.
RobertKusa Aug 29, 2012 05:16 PM
2007 Tucson limited
Having the same problem, thought it was the shoddy remote start I inherited from the previous owner, but now that I have disabled that I see it's not that easy. Has anyone else been successful at troubleshooting this?
PSUGUNNER Aug 30, 2012 09:11 AM
Panic Alarm Problem Solved
The problem has been solved. There was a recall on my ESC switch. I took the car in to get the switch replaced and I have no had a problem with the alarm since. It also fixed SEVERAL other electrical problems that I was having with my tucson. I suggest getting the ESC switch replaced if your VIN is part of the recall.
NovaResource Aug 30, 2012 09:48 AM
ESC switch? The one in the dash that turn the ESC on and off? I don't know about that recall. Do you mean the brake light switch?
RobertKusa Aug 31, 2012 05:37 PM
Well, no recall for my car according to Hyundai. But they alluded to the hood switch that I already had on order. So that makes me feel a little better. I might have had it fixed on my own, yeah! (Yes, I am easily entertained)
Venshy Sep 21, 2014 08:38 AM
Panic alarm going off
I just bought a per owned tuscon 2012, the dealer made me a new set of keys.
I drove it home yesterday. This morning when I tried to open ,the alarm went off and wouldn't stop.. Now I can't even start the car, help! anyone know what I should do?
NovaResource Sep 22, 2014 08:51 AM
Do you have the remote fobs for the car or just keys? If the alarm is set, you have to disarm it with the remote fob, not the key in the door.
