Please help!
1 Attachment(s)
I have a real problem car!! :confused::confused::confused:
Seems that nobody can fix it. I have had it to four Hyundai authorized garages and they cannot find the problem. The problem is that the car doesnt start, it cranks and then stops. I have filmed it aswell, you can listen to how it sounds when I try to start it. I have spend so much money on it that i honestly dont know what to do with it. Some info about the car: Hyundai Tucson 2.0 Crdi Year: 2006 / 2007 Diesel What should I do? Next week I will take the car to another garage, the last one are tired of the car! Their best man was sick, was their reason! :rolleyes: Down here i have written some of the tests the latst garage did:
When the key is first turned to the "ON" position, do you see on the instrument cluster the alarm symbol?
Does it go out when you start to crank the engine? If it does not then the alarm needs to be checked out. If it does then you don't have an alarm issue. You will need to go back to basics and check for fuel, spark, air, compression, timing, exhaust, etc Good luck |
Can you see it?
1 Attachment(s)
I uploaded a picture,, the one to the left is on "ON" and the oterh is when I cranks.
Originally Posted by avisitor
(Post 51959)
I'm sorry. Your vehicle is a diesel and I have very little knowledge about them.
Many stories about it being the high pressure fuel pump. But, as I said, I just don't know. Should try other Hyundai-forums.com |
