Repair advice 2013 Hyundai Tucson GLS
Old Jan 25, 2025 | 04:36 PM
Shenreice's Avatar
Default Repair advice 2013 Hyundai Tucson GLS
So my 2013 Hyundai Tucson GLS (Automatic, AWD, 2.4L) was stolen, and when I got it back there's a good amount of damage and a few problems I need to know how to fix. The ignition lock cylinder was removed (it still has the housing, just not the part the key goes in), steering column cover and wiper lever removed, crashed on the right bumper breaking the side mirror, headlight, foglight, and the edge of the bumper. The first big problem is that the airbag light is on and the horn no longer works. The steering wheel is still intact and it doesn't appear that the airbags went off with the crash. Could it be a damagedfuse or wiring, or is it likely something inside the steering wheel? I've heard it might be the clockspring? The door handle lock was broken, so I can't use the manual key in it. The power door locks still work to lock all the doors, but it only unlocks the drivers side (broken) door sometimes. So I don't know if i should replace the whole lock cylinder, since the internal parts are still in place? Other times I have to open another door and unlock it from the inside. I replaced the key fob battery, and the engine battery, but I don't know what else could be causing it to only work sometimes to unlock but it always works to lock it. It will also sometimes work if I lock it again and then try unlocking it again, but I'd say it's about 50/50 if it unlocks or not with the key fob. I know how to replace the ignition lock cylinder, but can anyone tell me where the wires are supposed to be plugged in? So many wires in the steering column are disconnected that I don't know what's what. Would it be the wire connection that's on the underside of the steering wheel, or is it something connected to the ignition housing? Any advice is greatly appreciated!
Old Jun 13, 2025 | 02:53 PM
Chiuvas2025's Avatar
Try to get manual for it i got mine here but i have 2024 tucson so cant help you would of send manual https://hyundaimanuals.net/product-c...rvice-manuals/
Reveles22
Aug 26, 2022 11:35 AM
Kimberley Lambert
May 22, 2021 09:25 AM
Kimberley Lambert
May 22, 2021 09:23 AM
Matt Gravel
Sep 4, 2020 04:55 PM
Matt_FSU'13
Nov 19, 2010 07:40 PM
