Rollover valve location inside tank
Old Dec 21, 2019 | 11:23 PM
Danny.r's Avatar
Default Rollover valve location inside tank
Can anyone please tell me where the rollover valve is located inside the tank? I replaced the fuel pump and it fell off and for the life of me I can’t find where it’s supposed to go
Old Dec 22, 2019 | 08:06 PM
Of all the pumps I have changed the roll over valve was internal with the pump module assy
Are you sure it belongs there?
Old Dec 22, 2019 | 10:05 PM
Danny.r's Avatar
it’s part of the vent system. The part of the vent line that goes on the inside of the pump assembly #17
Old Jun 2, 2021 | 04:00 PM
FastDarren's Avatar
Post need help with roll over valve location
Danny. Did you find out where that roll over valve goes inside the fuel tank. I have my fuel pump out now and same thing happened. roll over valve looks like just lying there in bottom of tank.
Help please. Darren Windsor Canada.
Old Jun 2, 2021 | 04:16 PM
FastDarren's Avatar
does rollover valve sit loose inside tank
Old May 13, 2022 | 04:08 AM
ivanrv1's Avatar
Default Help
Has anyone figure this out I’m having the same issue with my 2013 Tucson. Rollover valve is just sitting loose inside the tank. Is it somehow supposed to be attached somewhere inside the gas tank?
Old May 13, 2022 | 09:44 AM
All images of rollover valves for Hyundai fuel tank assys show a threaded end(s).
If it is something else, best way is to go to a Hyundai dealership parts dept and request to see a fuel tank unit.
They should either be able to either answer your question or let you see a new unit. It seems to be a common question .
Old May 17, 2022 | 06:13 AM
ivanrv1's Avatar
Default Thanks
I did go to my local dealership and all they told me is that it goes inside the gas tank. They have no schematics or anything to show me where its supposed to go
Old May 17, 2022 | 08:34 AM
I guess a lot depends on the person behind the counter.
What I suggested was to request to see a "Fuel Pump Module Assy", . Right then and there you would be able to see if that loose part belongs on the module.
Most parts dept personnel are usually cooperative. Maybe you didn't ask the right questions.
Old May 17, 2022 | 08:38 AM
ivanrv1's Avatar
Default Thanks again
thsnks for trying to help and you are right, maybe the person behind the counter was not willing to help. But I did ask the right questions, I even asked if they had a schematic of the gas tank I could purchase.
