SANTA FE 4 WHEEL DRIVE FAULT INDICATOR
Recently purchased a 2004 Santa Fe GLS with 4WD full time, and 2.7 engine. Owners manual states I should see a 4 wheel drive indicator on the left hand side of the instrument panel close to the engine fault indicator when I turn the ignition switch to the on position, which should go out after a few seconds. If this indicator comes on while driving it would indicate a problem with the 4WD. I'm getting conflicting advice from Hyundai sources. Is anybody with a similar configured Santa Fe getting this indicator? I obviously am not getting it and strongly feel I should be. <edited><editID>john199</editID><editDate>38317.698275463</editDate></edited> |
There is no indicator in your car, because the AWD indicator is for the 3.5ltr. V6, which has the electronic AWD system.</P> |
