Check engine light, code P2191, won’t go past 20mph
Hello, I have a 2016 veloster turbo, with 37k miles, check engine light came on and took to autozone to run scan on code, came up as P2191, system too lean at higher load bank 1, replace pcv valve and hose. The next day I drove and now the car will not accelerate past 20mph, would this be caused by faulty pcv valve and hose? Thank you
The vehicle electrical system is going into "Limp Mode". It does this to let the operator know there is a problem that requires correction now.
There are several possible causes and the best way to handle this is to have someone with a capable scan tool check out the data stream.info. |
Originally Posted by hanky
(Post 60638)
2016 should still have warranty. Engine issue.
The ECM has reached its limit in trying to compensate for air fuel ratio. You can have a vacuum leak where too much outside air is getting into the engine (unmetered air) Try spraying carb cleaner around the intake and listen for engine speed changes It could be stuck fuel injectors. Throw w few bottles of injector cleaner and see if it clears up It could be the IAV. Idle air control valve is stuck. Clean with carb cleaner Upstream O2 sensor could be faulty Would replace with OEM type. There are many levels of scan tools. All which use the data link connector of the OBDII Some scan tools are programmed specifically for the manufacturer It can read codes. Read all the modules. Activate bi-directional controls. Program the ECM and immobilizer, etc Scan tools can cost between 50 dollars to tens of thousands of dollars. Amazon sells the Autel which has many functions for a lower cost. Personally I bought the Harbor freight special Zurich ZR11. Should have waited to buy the ZR15 Or even got the cheaper Autel |
Thank you, I have ordered a obd like you have to get better information to pin point the problem, will arrive tomorrow
Just like when your doctor looks at your blood work, a tech looks at the data stream info and can often tell what is off spec under certain conditions.
We know fuel trim is involved , but we need to know other info to get a better picture of what is going on. Some include; RPM, coolant temp, MAF, rdg,oxygen sensor activity etc. If you can post the entire data stream info here for us to examine , that would help a lot. |
Was able to give it a proper scan with obd scanner and now two codes are present, same as before with the pcv valve, and now there is a P0191, fuel rail pressure sensor, would this be causing it to go into limp mode? If so what would be the fix? Thank you
If,,,,,,,,,,,,,the sensor or the info to or from it is not rational, the code will appear.
The best scan tool will maybe tell you the pressure if the sensor is working correctly, and maybe not. You do have a few choices, however, one is to just replace the fuel rail pressure sensor and hope that is all it was and if the problem is still present check to see if the info coming from the sensor is altered, or not coming at all which could be a wiring /connection problem. My suggestion is to leave this diagnosis and repair to someone more familiar with the system. |
Yes instead of throwing parts at it, dropped it off at dealership today, so should hear back soon
We would I"m sure appreciate it if you would get back to us and share you're vehicle's fix, thanks.
