replace Hyundai Veracruz Alternator
Hi I just upload a quick video on how to replace a 2010/11 Hyundai Veracruz Alternator as here in Brazil Hyundai did not make the recall.
My car was still under warranty but no deal with hyundai. So I bought a new one and replace it. Here is the link: |
good video. some say remove AC compressor and take out from below but i pulled out from the top. I just finished replacing my alternator and serp belt. I was having a few dash lights come on and headlights would flicker. The alternator output tested at 10.4 volts and of course it was caked with oil. mine is a 2008 veracruz limited 3.8L.
couple of notes I'd like to add. It took me about 4 hours. I pulled the pass side fan up from the top. The electrical clips are a pain in the butt. just getting them apart!! jabbed with a small screwdriver, pulled and pryed. I placed a 15" x 15" piece of cardboard against the radiator to protect it, then a thin piece of sheet metal in case the alt slipped. I took out both alt bolts but the bottom one is a cradle type bolt that just needs to be loosened. either way works fine. i sprayed the electrical connectors with a cleaner before putting back together, they were very wet and caked with oil. |
2008 veracruz
did he say that hyundai had a recall on this?
we have a veracruz, last year, broke down on interstate, lost everything electric. mechaninc said, new alternator was needed. so we borrowed 6oo dollars us to repair it. mechanic said 5 hours and had to pull the front grille, radiator etc. that was september 22 2018. today, broke down again, same symptoms. exactly a year later. seems strange to me. got to looking, the alternator is covered with engine oil. i looked closer and seems to be a gasket leak just above the alternator. 1, is this normal to have to replace the alternator this quick? 2, is there a way to replace the alternator without tearing apart the front end 3, is it possible to replace the gasket myself, i find this vehicle hard to work on due to lack of information online, and no manuals available. 4. is it worth having a mechanic to replace the alternator again, as well as replacing this gasket, she has 133,000 miles on her and shes starting to make some strange noises under the hood. |
| All times are GMT -5. The time now is 04:01 AM. |
