Air Flow Sensor removal and cleaning
Old Mar 21, 2008 | 12:22 AM
  #11
dikjenkins's Avatar
Default RE: Air Flow Sensor removal and cleaning
Thanks again Ken and to all of you who provided advise. I will do as is suggested and I will get back and report the results of my cleaning.
Old Mar 25, 2008 | 10:14 PM
  #12
dikjenkins's Avatar
I did clean the air flow sensor. I disconnected the harness plugging into the sensor, removed a couple of Marmon clamps and placed the unit in the utility tub. The intake end of the tube was protected by a course plastic mesh of the same material as the tube. Behind this mesh was a fine screen. I sprayed through the screen directly onto the upstream side of the sensor then flipped the tube over and sprayed the backside of the sensor. The unit looked clean even before I began.
Prior to dismantling the air flow sensor from the car I placed the car keys inside the house thus preventing me from starting the car without the sensor harness reconnected. The car doesn't seem to run any smoother. But it was a good experience to clean the sensor. It should be done on a regular basis when the air filter change is due.
The only slight problem I ran into was getting the harness disconnected from the sensor. There is a small tab in the top center of the connector. I pushed down with my thumb as hard as possible with no results. Finally I used a pair of needle nose pliers on the tab and it snapped down allowing the harness to release the sensor.
Thanks everyone for your help and advise.
Old Jul 21, 2019 | 01:16 AM
  #13
mikolko's Avatar
Theft in business organizations without automation leads to significant losses for owners due to insufficient control and accounting of commodities and materials. In such structures, it is difficult to identify productive and ineffective employees; there is no way to optimize the staff. Therefore, people automate managemart their business to avoid lots of problems.
Joy
Oct 22, 2017 08:20 PM
jmelantra
Jul 24, 2012 02:32 PM
mfm2010acc
Mar 29, 2012 08:52 AM
DrGreve
Nov 6, 2011 03:32 AM
dpwilliamsrn
Mar 15, 2010 04:40 PM
