Top Engine Cover Bolts
Old Oct 2, 2013 | 07:24 PM
EPS63's Avatar
Default Top Engine Cover Bolts
Does anyone know what size the bolts are that hold the top plastic engine cover to the engine on a 2002 XG350L? I purchased the vehicle about a month ago and the engine cover was missing. I purchased an engine cover, but do not have the bolts. Any help would be appreciated.
Old Oct 3, 2013 | 07:17 AM
Hyundai Mike's Avatar
most likely they are 6 mm or so.... most hardware stores do carry metric stuff in stock....
Old Oct 3, 2013 | 09:32 AM
EPS63's Avatar
Thanks for your help. You were correct about the 6mm bolt.
Old Mar 1, 2024 | 05:17 AM
johanbrandon's Avatar
Items/Tools Required:
Phillips screwdriver or flathead screwdriver for trimming
swap out the dashboard dome
Cut the Battery Off
Take off the dashboard trim.
Find the screws and remove them.
Take off the dashboard dome.
Cut the wiring, if necessary.
Put the New Dashboard Dome in Place
Reattach the wiring, if necessary.
Fasten using screws
Reattach the dashboard trim.
Link the Battery Test back in.
ebulich
Sep 30, 2023 12:28 AM
aritoularaptis
Jul 4, 2022 10:46 AM
rmanning87
Apr 25, 2010 08:08 PM
holt3332
Mar 13, 2010 07:04 PM
Danspeed1
Apr 16, 2006 12:46 AM
