2007 Hyundai Accent Gls Blower motor not working
Old Aug 1, 2021 | 02:36 PM
bigram69's Avatar
Default 2007 Hyundai Accent Gls Blower motor not working
Hello there I have a 2007 hyundai accent that the blower motor has stopped working. I have checked all fuses and they are good. I have check the relay it is good. I have checked the switch it is good. I have checked the motor it is good. I have tried tapping on the motor to see if it comes on and nothing happens. I have put it on speed 4 to by pass the resistor and it still doesn't come on. Could it be the switch that is bad. I need help please. Some advice would be greatly appreciated.
Old Aug 1, 2021 | 05:25 PM
I gotta tell ya , ya got me confused.
If you checked the motor and the switch and they are good, how can they be bad?
Seriously, the way to check the motor is to remove it and supply a direct power and ground to the motor. If it is good it will spin almost out of your hand.
Any slower, replace it.
Now if that test passes you know the motor needs to get full power to it for hi speed. The possibility of high resistance in the power supply to the motor could involve the switch or a module if your vehicle has automatic climate control.
Old Aug 1, 2021 | 05:28 PM
bigram69's Avatar
Maybe I am not testing the switch right. I did test the motor and it spun out of my hand.
Old Aug 2, 2021 | 05:37 AM
Can you try the motor test with the power coming from the usual source? That will give you some idea if the regular power path is not working correctly.
GTcrusin2773
Jan 10, 2021 04:13 PM
renfrance
Mar 26, 2020 12:14 PM
Kadeas
Jan 22, 2020 11:25 PM
oknaz
Feb 8, 2012 04:36 PM
Cartaphilus
Mar 5, 2008 03:26 PM
