2009 elantra p0016 code after belt change
Old Jun 18, 2019 | 05:04 PM
noodles's Avatar
Default 2009 elantra p0016 code after belt change
I recently change the timing belt for a gentleman that had 330,000 kms on his car and had never changed it. The belt looked surprisingly good. Also did a water pump change. When finished, I ran the car it had a p0016 code and was very sluggish. It starts and idles fine. I double checked the timing by pulling number 1 spark plug and inserting a probe to determine when the piston was at tdc. As the probe peaked out the cam sprocket was at the indentation as well. Everything looked good so I ordered a cam sensor and just changed it today. I cleared the code but it returns on startup. Any suggestions would be helpful.Thanks
Old Jun 18, 2019 | 07:48 PM
avisitor's Avatar
Sounds like you know what you're doing.
Piston at TDC
Valves all closed
P0016 cam and crank correlation??
I would be just going over it again and again to see if I missed something
Old Jun 19, 2019 | 02:39 PM
If the belt is one tooth off it will throw that code.
Good advice to recheck your work.
Old Jul 15, 2019 | 10:01 AM
noodles's Avatar
Can the belt be off 1 tooth and still start and run well with no valve damage?--- I'll answer that 1 myself. Yes it can but it will certainly throw a code. Not sure how many teeth u could be off without damage and I don't want to find out.
Old Jul 23, 2019 | 01:38 PM
noodles's Avatar
Well Fellas today was the day I was gonna figure this out or die tryin. I pulled the top timing cover and when the piston was at tdc my mark was just not quite lined up on the cam. I still figured if I jump the cam sprocket 1 tooth it would be way passed the mark. Previously as soon as I started it after clearing the code it would fire a new code. I loosened the tensioner and jumped it 1 tooth and re tried the mark . To me it seems like its just passed where it should be about the same amount it seemed early before. … but ya know what? When I start it up no codes and she has her pep back. Was pretty dead on take off before. She's back to her old self and I learned something the hard way. Everyone that said I was out a tooth was bang on- thanks.
Old Jul 23, 2019 | 04:48 PM
Glad you decided to recheck, always nice to know when a problem has been fixed. Thanks for the update.
Old Jul 23, 2019 | 11:06 PM
avisitor's Avatar
Yeah, thanks for the update.
Glad you found it.
cnfsd
May 19, 2019 10:56 AM
TucsonIowa
Aug 27, 2018 10:12 PM
Moondog66
Jul 22, 2016 11:23 PM
mikeyrod
Jul 10, 2014 09:49 AM
Paul Romanovich
Feb 19, 2012 09:34 AM
