2103 Sante Fe Sport 2.0T rear window issue
Good evening. I have a 2013 Sante Fe Sport 2.0T and the driver side rear window will no go up or down with any of the switches. Does anyone know if this is just a motor issue or something else? All other Windows work fine with all switches. appreciate any help. Thanks!! |
You narrowed it down quite a bit.
What you might consider is to remove the interior door covering and actually verify power and ground are available for the motor. Usually that window is not used that much and there is a good chance the motor and assembly are still good. |
Thank you for the reply. I plan on removing the interior panel and checking the connections this weekend. Hopefully something just shook loose. I checked the fuses and they are fine as well.
