No fire
Old Apr 19, 2021 | 11:45 AM
Chewy 1475's Avatar
Default No fire
I just put a motor in my azera. I got the engine from a local salvage yard they checked the vin to make sure the numbers matched and guaranteed the engine to run, with leaves me to assume they heard it run before they took it out of whatever car they got it from I have everything plugged in and connected the way it was when I took it out. But I am getting no power to my coil packs. I have checked all and replaced fuses wether they looked bad or not.
Old Apr 19, 2021 | 12:08 PM
In the process of R & R the engine, I'm sure you had to unplug some plugs and reconnect them when ready. Without a diagram to refer to , you might have to do it the hard way and physically trace the wire back that brings power to the coils when the key is on. Don't know at this time if immobilizer feature is on vehicle or if it is functioning.
You might bring a fused temporary power supply to the coils and see if that allows it to start.
Old Apr 19, 2021 | 12:15 PM
Chewy 1475's Avatar
I don't have any power to the fuse for the ignition coil. Fuse 21 in my box. I jumped a hot wire directly to the fuse. The fans kicked on but that was the only thing that changed. I still got no power to the coil packs
Old Apr 20, 2021 | 05:39 AM
Start tracing back from the coils and look for where power is lost..
scant17
Apr 20, 2021 05:52 AM
crparmy
Mar 18, 2018 10:21 AM
collegemike
Aug 13, 2011 06:05 PM
pistachio
Jun 28, 2011 02:41 AM
AManiscalco2007
Jan 5, 2008 07:26 AM
