Radio Volume settings change after phone call
Old Feb 3, 2022 | 03:52 PM
SLU2's Avatar
Default Radio Volume settings change after phone call
I have a 2018 Hyundai Tuscon. My radio volume settings change after receiving a phone call via bluetooth. I have the front and rear volumes centered before the call and after I hang up, the settings go to All Rear settings. Haven't been able to figure it out other than moving the volume setting back up from the rear to the center after parking the vehicle(won't let you do it in gear). Any help is appreciated..
Old Feb 3, 2022 | 04:45 PM
A suggestion ,
Try as many different situations as you can to see what conditions allow that volume to change.
What you would be attempting to do is; see what conditions are active and which are not when this happens.
Then we would look for what those conditions have in common and go from there.
Old Feb 3, 2022 | 09:58 PM
SLU2's Avatar
Other than after getting a phone call, haven’t noticed the volume changes any other time.
Old Feb 4, 2022 | 10:46 AM
Could it be there is some signal coming from your phone that your vehicle's radio is picking up?
Is it possible for you to try another phone set up? See if it does the same thing , if it does at least we would know it is not the phone causing the problem.
Old Feb 7, 2022 | 11:52 AM
SLU2's Avatar
Nothing else is connected except the blue tooth for incoming phone calls. It happens every time an incoming call is present even if I don't answer it. SMH
Old Feb 7, 2022 | 03:54 PM
Next question,
When you are getting an incoming call, how does it notify you ?
What I am try to determine is , If a certain signal is coming through, say a ringing sound, that could generate a stray signal that your radio is picking up.
It sounds a little far out, but with electronics strange things can happen. AND something like this is not really that far out !
Old Feb 7, 2022 | 04:20 PM
SLU2's Avatar
Default Phone signal
I believe the phone rings and vibrates and the dash display indicates incoming call with the Green(pickup) Red(hangup) icons.
Old Feb 8, 2022 | 02:36 PM
Did you attempt to go into the "Settings" on your dash display? You may be able to alter that feature. I believe some systems will lower the volume when a phone call is received ,(In this case it is shifting the balance setting to all rear ) so the person receiving the call can hear better.
Old Feb 8, 2022 | 04:07 PM
SLU2's Avatar
Default Radio volume
I'm not sure what settings to check but I'll give it a look...
Old Feb 9, 2022 | 10:39 AM
What does your owner's manual say regarding this feature? Many times the instructions are in the manual.
