santa fe 07 difficulty start and limp home transmission
Old Nov 19, 2021 | 06:10 AM
mendte's Avatar
Default santa fe 07 difficulty start and limp home transmission
i recently bought a 2007 santa fe 2.7l gasoline and it had a slight engine failure. It takes time to turn on and the transmission locks up after rolling in 3rd gear. i used the bluedriver and the fault codes are as follows
Confirmed codes
P0717 Input speed sensor
replace the sensor and the problem remains. I have doubts about the cables of the pins, in a diagram I saw that pin 1 is ground, pin2 is 5v signal and pin 3 is 12v power. This is the same as the output sensor. In a diagram shared by Mr KEN in an old post, administrator of this forum, it appears that the input sensor, pin 1 is ground, pin 2 is 12v power and pin 3 is 5v signal. In my truck it seems that in both sensors the 5v signal was pin 2 as measured. I'm a bit confused here
P0340 Camshaft position sensor bank 1
i replace the sensor and still the active code. I measured and I have present the 12v signal and ground in the connector
Pending codes
P0462 fuel level sensor circuit low
p2067 fuel level sensor b circuit low
p2065 fuel level sensor b circuit
p0452 evap. emission ctrl. system- pressure sensor low input.
When I bought the truck it did not show the fuel level. Then I changed the complete assembly of the fuel pump, I checked the resistance of the sensor b and it was fine. now it correctly marks the fuel level in the cluster, but it keeps showing me these codes.
My fuel pump model not have the pressure sensor on the top, so im confused about the p0452 code.
P0501 Vehicle speed sensor range performance
I changed the pinion gear on the speed sensor because it had a broken tooth. it continues the same code and does show the speed in the cluster
P0447 Evap emission ctrl system vent circuit open (SOV)
Im not checked yet
p0057 O2 sensor bank 1 sensor 2
p0037 O2 sensor bank 2 sensor 2
Im not checked yet, but i consider less relevant codes
please help me
thanks in advance
Old Nov 20, 2021 | 03:52 PM
A good part of the time when we get a bunch of unrelated codes, there is a poor ground connection that serves the affected components. You might start with looking for something like that
Bigblock57
Sep 9, 2019 12:56 PM
Rock4Jesus777
Feb 26, 2016 02:30 PM
racing1219
Aug 29, 2014 06:56 AM
ma1559
Apr 30, 2007 11:29 PM
Tim_E
Jun 4, 2006 06:10 PM
