Off Topic A place for you car junkies to boldly post off topic.
i10 2010
Old Jun 15, 2020 | 11:51 AM
Timbo's Avatar
Default i10 2010
Hi all,
first post here!
just got car back from garage
i think I've been stitched up!
took car in following an issue where when car was put in 3rd gear the engine power was transferring until a few seconds later after clutch raised.
garage informed me clutch plate, cover and release bearing needed changing and gear box had to be stripped and cleaned up
just had bill of £1003 !! FFS, Ive attached invoice to show billing
here is itemised invoice
Have i been ripped off? or is this fair?
seems so expensive!!
if so what course of action should i take? get an independent analysis?
any help most appreciated
cheers
Timbo
HELP!
Old Jun 15, 2020 | 03:45 PM
I would like to provide a valid comment, but I am having a problem understanding why they did what they "Said they did" because the work ,right now, just doesn't match the symptoms. As far as the cost, you might get better results checking with a shop or two closer to home
Old Jun 15, 2020 | 04:52 PM
Timbo's Avatar
what i can't understand is why have I been charged for 7.4 hours labour (£400 inc vat) and a gearbox box repair cost of £474 inc vat!?
surely the time taken in labour would have covered the gearbox rebuild? it seems I am paying twice for the same thing!
or am I missing something?
Old Jun 16, 2020 | 03:57 AM
The clutch system is a separate part from the transmission (Gearbox). We don't usually get into the gearbox unless there has been damage to any/some of the internals.
The gearbox has to be removed to replace the clutch pieces and they are separate from trans.
Can you tell us just what was the original problem?
Old Jun 16, 2020 | 06:04 PM
Timbo's Avatar
Hi
the original problem was that at around 2.5k revs when changing from 2nd to 3rd gear when clutch lifted there was a feeling that the car wasn't pulling correctly for about 1 second or so, garage tell me that the seal between gearbox shaft was leaking onto clutch plate causing slippage.
he had to change the seal/bearing inside the gearbox shaft and also changed the bearing feeding clutch release bearing and its retaining clip that had snapped off on one leg.
hope that helps?
cheers
Tim
Old Jun 17, 2020 | 07:23 AM
The explanation does make sense and it does appear to be fair.
Most of us don't care to do extra work if we don't have to, but the explanation kinda covers it pretty well.
There is nothing wrong with getting other opinions if you want to do that.
Old Jun 17, 2020 | 09:14 AM
Timbo's Avatar
thank you for your input, most appreciated hanky!
Old Nov 9, 2022 | 06:29 PM
Paul D. Soriano's Avatar
Sounds expensive today. Is the original master qualified? What caused the initial breakdown? It won't happen again, any guarantees?
Old Nov 9, 2022 | 07:04 PM
Hi Paul,
Welcome aboard.
Something you might want to check,
Always a good idea to look at the date of the post. In this case the date was 2020 and they probably got rid of the vehicle by this time.
Something else you might notice,
Very few folks will get back to us to let us know how they made out, they get an answer and if it works they might get back to us and maybe not.
Nicmills1
Jul 9, 2017 01:00 PM
streets455
Jul 27, 2011 01:36 PM
SharonScott
Off Topic
Oct 26, 2010 11:15 PM
trevy1100
Off Topic
Jan 14, 2008 11:49 AM
coolairvw
Sep 8, 2007 10:01 AM
