Suspension Talk about your suspension within.
Reg. Brake calliper location
Old May 23, 2012 | 06:41 AM
sashidhar84's Avatar
Default Reg. Brake calliper location
Hi all,
I have a specific query..n i m very interested to know about the following thing..
In some cars, brake calliper is located infront of the front strut but in some cars it is located in the rear of front strut. The same is the case of rear brake.
Why is the calliper location differs from vehicle by vehicle...?
The location is being changed based on the vehicle segment or weight..??
if anyone knows the reason and the design concept, pl let me know.
Old May 23, 2012 | 07:54 AM
Placement does not affect the performance. It's placed in the location that clears the other suspension parts.
Old May 24, 2012 | 02:38 AM
Default Brake caliper location
Thanks NovaResource for the reply...
But jus consider the wheel the rotating in clockwise direction and you are seeing from outside...
In this case, when the brake caliper is placed in front of strut, the force exerted on the disc is towards the gravity.
Whereas if the disc is placed in the rear of the front strut, the force is away from the gravity...
Does this have some impact in braking performance of the vehicle..?
Old May 24, 2012 | 07:39 AM
Gravity has nothing to do it it.
Lots of cars put the caliper on either side of the suspension. Porsche for example:
Bottom line: It Doesn't Matter.
nev
Feb 6, 2012 07:37 AM
thrakka
Jul 21, 2011 09:55 PM
sashidhar84
Dec 1, 2010 07:28 AM
bob_351c
Jun 28, 2010 05:36 PM
dazmedwaykent
May 19, 2009 04:58 AM
