Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
DVD GPS Radio from CUSP
Old 01-19-2014, 11:31 AM
MrForce's Avatar
Default DVD GPS Radio from CUSP
Hi
I have installed a DVD GPS Radio with Android system from CUSPtech in my Hyundai Sonata 2009.
I have a problem, that I hope you can help me with.
About 2 minutters after I have turned the radio off (ignition key set to off or removed), then the radio (Android system) starts from the beginning (cold starts) when I put the power back on, but if I switch the power to the radio back on before the about 2 minutes has gone, then it starts up in the system state as when I switched it off (as it should do!).
I have been measurering the voldtage and the 12 volts on the "battery wire" is active all the time, also when the ignitionkey is removed (as it should be!).
Have someone an idear what the problem can be ?
Many regards
MrForce
Denmark
Old 11-21-2016, 02:34 AM
Brianstrong's Avatar
You can check all the cables to see if they are connected correctly because sometimes if any of the cables is wrongly connected, this issue will happen, I get similar issue before.
stressbaby
11-21-2016 02:54 AM
RACHEL
07-26-2012 01:00 AM
gettoboy
04-16-2012 12:57 PM
qqlove
07-04-2010 04:46 AM
menacez
12-10-2005 03:43 PM
Quick Reply: DVD GPS Radio from CUSP
