A/C manual switch not working, the compressor not working
Good Afternoon,
I was try to repair/ clean the flout Gauge of fuel indicator in the fuel tank but after put in back, a lot of problem come out such as:
1. If I start to heat up the engine in idle stationer, the engine was unstable/ like clogged up, look like not enough oxygen then after a few time the engine stop.
2. A/C manual switch not working, the compressor not working…only the hot air come out from the engine.
3. Washer pump not working anymore. Only the Whiper is working.
I do not know the relation between these problems with the float gauge that I was take a part, but before that there is not such a problem, kindly help me to give the explanation/ brightening to solve this problem…
. Thank you very much.
