2012 Tucson AWD 2.4L Rough Rev @ 1800-1900RPM
Old 08-19-2017, 10:25 PM
dlshunter's Avatar
Default 2012 Tucson AWD 2.4L Rough Rev @ 1800-1900RPM
I recently noticed that our Tucson described above has a very noticeable rough range right at about 1800rpm, then goes away after 2000rpm regardless in park or neutral, AC on or off, ECO on or off, and when accelerating slowly through the gears. It will not do this when you get on the pedal from a stop. I cannot find anything specifically on this topic, but I have read of other makes/models doing this, and the fix is either...
(1) Clean MAF, (2) Look for air intake leaks between MAF and TB, then (3) Crankshaft Position Sensor.
Any similar problems out there?
forestjohnson
10-04-2023 04:52 PM
2000ELANTRA
09-29-2007 03:04 PM
alvinsum
03-01-2007 07:39 AM
Quick Reply: 2012 Tucson AWD 2.4L Rough Rev @ 1800-1900RPM
