Hyundai Azera A Hyundai like you've never seen before.
07 Azera won't start
Old 12-23-2016, 12:36 PM
1newyears62's Avatar
Default 07 Azera won't start
I have a 2007 Azera that I just replaced the battery and starter in,all the lights work, clock still works, and the remote opens the door. But, the car wont start. Help please!
Old 12-24-2016, 12:48 PM
avisitor's Avatar
Does the engine crank? And not start?
Or, does the engine crank and not start?
If it does not crank then check the battery and terminals for corrosion.
See if there is a bad ground. Test light on negative terminal and the light touching the engine block, then crank. If Test light bulb lights up then bad ground.
If not then check the starter relay. See youtube videos on how to test a (starter) relay
If engine cranks but does fire up then check for the basics
Fuel, spark, compression, timing, exhaust (blockages)
Old 03-09-2018, 12:38 PM
hichamaziz's Avatar
Old 03-09-2018, 11:35 PM
avisitor's Avatar
Yeah, would have help others if the person would have came back for an update or fix
sipos
02-01-2011 07:45 AM
Hatdrawn
04-27-2010 08:49 PM
D_nice
12-04-2005 07:36 PM
virtual231
10-26-2005 01:04 AM
gnzlztwice
08-02-2005 01:26 PM
Quick Reply: 07 Azera won't start
