1999 Hyundai elantra fuel issue
Old 08-15-2014, 12:11 PM
walterg6's Avatar
Default 1999 Hyundai elantra fuel issue
So yesterday i replaced the canister purge valve in the evap system due to 2 different error codes pointing towards it being bad. Also did a wheel bearing replacement new wires and new spark plugs due to the fact the old plugs were burnt and gapped at like 0.065. Ever since pulling the battery cable for a few hours to reset the codes while doing all this work the car now stutters a lot and has trouble idling. It also smells like its getting too much gas. It will randomly stall whenever i let off the gas and coast or slow down for traffic lights. Looking for where to look Now. Is it just the computer needing to re learn everything and i just wait it out? Do i need to pull the throttle body and thoroughly clean it? Some other sensor i need to look at? Thank you in advance for advice.
Im Walter. New to this thread.
Old 08-20-2014, 06:56 AM
I'd check the plugs and wires first. It's possible there's a bad connection or the gap on a plug got closed while installing them.
Old 08-22-2014, 01:59 PM
walterg6's Avatar
Checked plugs and wires. Issue existed before new plugs and wires. Gap was correct wires all had good connections. Dealership wants $104 plus tax to diagnose each sensor and tell me where the issue is. Guess ill post here next month with the fix. Each sensor is over $100 each i don't have money to take shots in the dark
Old 08-26-2014, 07:27 AM
What were the codes you were getting?
Old 08-29-2014, 11:59 AM
walterg6's Avatar
P0441
P0446
Were the only codes the computer had before reset
zorkman2000
03-15-2015 04:12 PM
Fireknight
12-01-2011 08:10 AM
jalexa101
06-27-2011 06:49 PM
jweidler
04-30-2007 01:51 AM
Rebelforce
03-18-2007 09:44 PM
Quick Reply: 1999 Hyundai elantra fuel issue
