Fuse / Relay info needed '96 Elantra GLS
Hello All,
I don't own a Hyundai, but my neighbor does. Her POS ex-boyfriend came by in the middle of the night and yanked all the fuses & relays out of her '96 Elantra and now she does not have a car to drive. Nice guy, huh?!
Anyway I told her I'd take a look, but the bastard also took the fuse/relay box cover so I have no point of reference as to what needs to be replaced. Can anyone post a pic of the fuse/relay on the bottom of the cover so I can help her put her car back on the road?
Help would be greatly appreciated.
J.
J.
RE: Fuse / Relay info needed '96 Elantra GLS
FUSE/RELAY INFORMATION
Engine Compartment Fuse/Relay Box
Fuse - Amps - Circuit Protected
A/CON - 10 - A/C compressor
HORN - 10 - Horn
BURG ALARM B+ - 10 - Data link connector, Electronic time and alarm control module, Engine control module, Instrument cluster, Interior lights, Radio, Transmission control module
T/LP (LH) - 10 - Interior lights, Exterior lights
T/LP (RH) - 10 - Exterior lights
H/LP (LH) - 10 - Headlights
H/LP (RH) - 10 - Headlights, Indicators
Fuse Link - Color - Amps - Circuit Protected
A - DK BLU - 100 - Power distribution
B - BLU - 20 - Cooling fans
C - BLU - 20 - Engine control module, Charging
D - BLU - 20 - Anti-lock brake system (ABS)
E - PNK - 30 - Power door locks, Power windows
F - PNK - 30 - Ignition, Starting
G - PNK - 30 - Exterior lamps
H - PNK - 30 - Blower controls
I - RED - 50 - Power distribution
J - PNK - 30 - Anti-lock brake system (ABS)
K - PNK - 30 - Cooling fans
Passenger Compartment Relay Center
[/align]DASH FUSE BOX[/align][/align]Fuse - Amps - Circuit Protected
1 AIR CON - 10A - A/C controls
2 DR C/LOCK - 15A - Power door lock
3 STOP LP - 15A - Automatic transaxle, Interlock system, Stop lamps
4 HAZARD - 10A - Hazard warning
5 RR HTD - 30A - Rear defogger
6 SUN ROOF - 15A - Sunroof
7 RR WIPER And WASHER - 15A - Rear wiper/washer
8 WIPER, ETACS, WASHER - 15A - Front wiper/washer, Electronic time and alarm control module
9 B/UP LP, T/SIG LP - 10A - Automatic transaxle, Back-up lamps, Charging, Engine control module, Turn signal lamps
10 ETACS, CLUSTER - 10A - Electronic time and alarm control module, Instrument cluster
11 ABS - 10A - ABS
12 AIR BAG - 15A - SRS
13 C/LIGHTER, O/S MIRROR, CLOCK - 15A - Cigarette lighter, Clock, Power door mirrors
14 AUDIO, ATM INTERLOCK - 10A - Interlock system, Radio
15 ECT - 10A - Automatic transaxle
16 SUN ROOF, H/LP, A/CRUISE - 10A - Cruise control, Sunroof, Head lamps[/align][/align]
HORN - 10 - Horn
11 ABS - 10A - ABS
