gas mileage problem
Old 08-08-2006, 07:13 AM
kuyi84's Avatar
Default gas mileage problem
I own an '03 Elantra gls.. and I've been getting poor gas mileage for the past while. I filled my tank a few days ago.. I've only driven about 50 miles, and already I'm down a quarter of a tank. Any ideas as to what's goin' on??
Old 10-22-2006, 01:01 AM
Jlivan's Avatar
Default RE: gas mileage problem
From least to greatest check on the following: Oil, fuel filter, spark plugs & wires (distributor cap/rotor), O2 sensors, muffler, & timing belt. I say if you change the first 3 and still are having problems then maybe take it in to check diagnostics.
Old 11-02-2006, 09:26 AM
graham7773's Avatar
Hi to Jlivan. I own a 1994 1.8litre Lantra which is the ame as the Elantra and it does not have a distributor. It has a coil pack controled by the computer. I think this setup is standard. Did Hyundai change back to distributors in the later models?
Old 11-21-2006, 09:55 PM
gary2's Avatar
bad oxygen sensor will cause poor gas mileage
Old 12-11-2006, 10:11 AM
LeChuck's Avatar
I don't want to scare you, but it wouldn't be the first time, that a tank has shrunken to half size. A friend of mine had this problem with his Opel Corsa and it must be an issue every now and then with many brands. Not only Hyundai.
Old 12-22-2006, 10:16 AM
Da_Roach's Avatar
Definitely oxygen sensor or plugs and wires. My mechanic said it is very rare for a fuel filter to go bad. I changed my Ox sensor at 80,000 miles, big difference, changed plugs and wires twice, big improvement.
spaceship22
04-11-2012 04:13 PM
coolhand
01-06-2007 01:36 PM
multi
03-16-2006 06:55 PM
raffi
12-09-2005 05:29 PM
aksentOner
04-14-2005 01:56 AM
Quick Reply: gas mileage problem
