2006 Santa Fe Code Help
Old 08-09-2012, 04:57 PM
drummer125's Avatar
Default 2006 Santa Fe Code Help
Hello to all.
My check engine light came on several weeks ago. I finally had the money to have the codes read. The codes that showed up was: P0151 and P0154
which I believe to be an oxygen sensor.
I called the local dealer, service said it would cost $350
I don't have this kind of money. I lost my job 6 months ago.
If anyone can give me some help, I would greatly appreciate it. I would like to try to change this myself.
2006 Santa Fe 3.5L 6 cylinder
Thanks
Old 08-09-2012, 09:16 PM
Yeah, both codes point to the Bank 2 Sensor 1. That's the easiest sensor to get to. It the sensor before the converter on the radiator side of the engine.
Bank 1 is always the side of the engine with cylinder #1.
Bank 2 is always the side of the engine with cylinder #2.
Bank 1 is the bank of cylinders on the firewall side.
Bank 2 is the bank of cylinders on the radiator side.
Old 08-09-2012, 10:46 PM
drummer125's Avatar
Thanks NovaResource, Much appreciated.
Is that the sensor located below the plastic engine cover, almost dead center, if I'm standing in front of the vehicle looking down, and the driver's side is to my right ?
Would you happen to have a part number.
I've been doing more research since I posted this. It seems like this vehicle has a total of 4 sensors. I believe that one is called the "upstream" O2 sensor. It seems like there's 2 "Upstream", and 2 "downstream" O2 sensors ( one downstream Left, and one downstream Right )
Please let me know.
Thanks again.
Old 08-10-2012, 06:47 AM
That's what I said above. There are 4 O2 sensors, 2 on each side of the engine. Bank 1 side is the side facing the firewall. Bank 2 is the side facing the radiator. On both sides there is one sensor before the converter (aka "upstream') and one after the converter (aka downstream). The code is indicating the Bank 2 Sensor 1 is bad. This is the "upstream" sensor on the side of the engine facing the radiator.
degetel77
05-05-2015 01:48 PM
atikovi
12-13-2012 07:19 AM
ciggy
07-11-2012 12:15 PM
TomV
12-07-2010 04:45 PM
blackbox19
08-06-2010 09:59 PM
Quick Reply: 2006 Santa Fe Code Help
