Santa Fe 2003 2.7 front engine mount replacement
Old 01-11-2012, 06:56 AM
gary_c's Avatar
Default Santa Fe 2003 2.7 front engine mount replacement
Any tips on how to get the mount out after supporting the front of the engine? Does the whole mount bracket attached to the engine need removed or can you just remove the rubber mount piece attached to the front frame out?
Thanks
Old 01-11-2012, 05:49 PM
gary_c's Avatar
I figured it out. If you take out the bottom bolt on the engine bracket and loosen the top bolt you can rotate the engine bracket just enough to slide the rubber mount pass the crossbar.
stu999
07-02-2011 12:37 AM
baja
03-14-2010 09:54 PM
Accentcrazy
10-10-2007 09:53 PM
Chris0628
10-31-2006 01:18 AM
toolazyforalogin
02-15-2006 11:59 PM
Quick Reply: Santa Fe 2003 2.7 front engine mount replacement
