Camshaft Position Sensor Installation plz help
Old 04-08-2008, 08:02 AM
treyclash's Avatar
Default Camshaft Position Sensor Installation plz help
ok so the code was the tps and the camshaft postioning sensor..... so please if anyone has any info on were it is or how hard it is to install plz let me kno. any pictures telling me were it is located or how to install will help ALOT. thanks. 2003 tiburon gt
Old 04-08-2008, 08:41 AM
Default RE: Camshaft Position Sensor Installation plz help
Old 04-08-2008, 09:29 AM
treyclash's Avatar
its the crank shaft not cam sorry lol. thx
Old 04-08-2008, 09:32 AM
treyclash's Avatar
is it hard find wen u get into and change it out? how long do u think it may take to put in a new one? my buddy doing it says he thinks u gotta take like the side of the engine off to get to it but idk. wat is your opinion or have u ever seen it done?
Old 04-08-2008, 11:02 AM
Both the cam (CMP) and crank (CKP) sensors are listed in the pic. I believe both are accessible without removing anything major.
Old 02-26-2010, 12:02 AM
archebald23's Avatar
Banned
thanx for the diagram, i was planning on bringing my car to a mechanic to replace the Camshaft Position Sensor but he quoted me too much so i figured i could do a DIY and i did, with the aid of your Diagram. again, thanx.
Old 03-13-2010, 04:50 PM
jpen27's Avatar
Archebald 23,
hey I just installed the KPS on my tib not hard at all, just make sure its set in there correctly before you start the car again. the best way I found top install was to go from the bottom and over the starter (pure fill, not way to see what your doing from there) good luck.
P.S. for the location of the sensor its right about the starter. dont have to remore anything and the part only cost about 65.00 dollars...
10mm 1/4 drive socket that's all
Old 03-13-2010, 07:14 PM
Default Hate to rain on parade ----
But the picture posted above is severely incorrect !!
Do you have the 4 cyl or the 6 cyl ??
6 cyl:
The Cam Position Sensor (TDC sensor) is located on the rear of head for bank 1, stuck into an aluminum cap/cover thing...
The Crank Position Sensor (CKP) is mounted to radiator side of block,,, behind the starter..
4 cyl :
CKP is on radiator side if engine, kinda in line with cylinder #4
CMP is on cylinder head, intake side, near the timing belt cover, sticks out of head
Old 08-05-2013, 09:01 PM
lujo17's Avatar
What is the trick to remove the camshaft sensor becuse I tried and fail. In the v6. Thanks
mybroketib
11-29-2010 01:49 PM
01tibby
09-21-2010 08:24 PM
leiladrue
03-10-2007 10:09 PM
Anton4daze
07-11-2006 12:00 AM
Quick Reply: Camshaft Position Sensor Installation plz help
