Help with Keyless entry problem
Hello, I have an 03 Hyundai Tiburon. Great car.
But I locked the car with keyless entry system. I go to use the keyless to go to lunch, and it seems not to respond.
The car will not unlock with the keyless, So I use the regular key and set off the alarm. However, the car won't start even when i put the key in the ignition. I beleive it may be a security feature.
So I bought a new battery at radioshack for the keyless. The employee doesn't know how to replace the battery.
I opened it up. THe battery seems to be held in place by three prongs, but they won't budge, and the battery won't come out.
Does anyone know how to replace battery? Am I going about this problem the correct way?
Thanks for your help.
Solution to first problem: Unlock the door with the key, open the door (alarm will sound), get in and turn the key to the ON position but do not start the car. Wait until the alarm stops (that may be a minute or two). When the alarm stops, try to start the car. This "USUALLY" works.
Solution to second problem: You need to pry the battery out without damaging the prongs. It usually just slides out.
Both problems are addressed on page 1-5 of your owners manual:
