Suspension Talk about your suspension within.
Rear Camber Out of Specs
Old 04-02-2012, 07:24 PM
DSG's Avatar
DSG
DSG is offline
Default Rear Camber Out of Specs
My girlfriend recently inherited a 2000 Hyundai Accent from a deceased family member. This vehicle was immaculately kept and serviced regularly. I noticed that the rear right-hand tire is wearing irregularly. I looked through the service paperwork and found the rear camber in the right-hand side to be out of spec. It also stated it was "adjusted to max." The camber is not adjustable from what I have read. So, my question is, what part or parts of the rear suspension are responsible for controlling the camber and may be in need of replacement/repair? Thank you in advance to those of you whom reply.
Old 04-03-2012, 07:51 AM
It's possible but I'd have it check by a mechanic first.
Old 11-03-2018, 02:08 AM
hyundaicaner's Avatar
Hello. Firstly, get well soon. Suspension system is a very important piece for the car.
In case of breakdown or malfunction, it leaves you exposed to great hazards. If you do not have knowledge and experience when it malfunctions, take it to a dialer.
You can reach a wide range of information about suspension: https://bilgihanem.com/suspansiyon-sistemi-nedir-nasil-calisir/
Hopefully it benefits your business.
Sterling570
06-03-2019 02:33 PM
alatini
10-26-2015 09:20 AM
Mcknapp3
03-28-2012 02:11 AM
mikey500
10-29-2011 08:53 AM
Green97GLS
05-07-2009 09:06 PM
Quick Reply: Rear Camber Out of Specs
