04 Sonata help
Old Nov 2, 2019 | 09:12 AM
DAYBO555's Avatar
Default 04 Sonata help
Ok I've got a 04 Sonata 2.7 v6 that had been parked away for about 17 months, I bring it out of rest and start her up, runs little rough at first but smooths out ( drove about 200 yards) and it begins to run rough sitting in park, doesn't want to go then the worst smell of rotten eggs fills cabin and it does, won't run then.
So catalytic convertors are removed and have clear exhaust car will start run about 5 seconds then dies. The fuel pump also puts out when key turned on then stops, have to turn key off back on to start pump again which runs a few seconds then off again, what am I missing anyone please?
Old Nov 3, 2019 | 02:43 AM
The fuel pump is supposed to prime the engine for approx 2 seconds when the key is first turned on. That confirms the computer,fuel pump relay and fuel pump are probably working.. What could be missing is a crank sensor signal to the computer so it knows to keep the fuel pump relay energized and keep supplying fuel.
Crank sensors don't always throw a code and they have been troublesome on Hyundai vehicles.
Old Nov 3, 2019 | 08:58 PM
avisitor's Avatar
Do you still have the O2 sensors connected?
Do you know how to bypass a fuel pump relay?
Try using starter fluid to keep engine running
If it works then fuel pump is not be energized while engine running
When was the last time the timing belt was changed?
Old Nov 4, 2019 | 08:04 AM
allegretto's Avatar
Bad fuel could be an issue as well.
Caleb Green
Jul 18, 2019 04:15 AM
1OldDude
Jan 24, 2018 10:30 PM
makowski306
Nov 7, 2017 03:19 PM
go-rebels
Jul 19, 2016 07:08 AM
Stamford
Sep 26, 2013 06:49 AM
