16 Genesis Sedan Keyfob Doesn't Lock/Unlock Doors and Trunk Doesn't Open
Old Jan 26, 2024 | 05:10 PM
xps15z's Avatar
Default 16 Genesis Sedan Keyfob Doesn't Lock/Unlock Doors and Trunk Doesn't Open
Having electrical issue that myself, my mechanic, nor Hyundai can detect.
What Doesn't Work:
- Locking door from outside driver and passenger handle
- Unlocking door from outside driver and passenger handle
- Locking and unlocking door with keyfob
- Opening the trunk with the smartkey fob
- Opening the trunk with the interior trunk button next to steering wheel
- Opening the trunk by pushing on the physical touch pad
What Works:
- Locking door from inside drivers door
- Unlocking door from inside drivers door
- Locking and unlocking door via scanner plugged into OBD2 port
- Putting car in reverse will lock doors.
- Putting car in park will unlock doors.
- Opening the trunk with the physical key inserted
I am curious if someone has suggestions on what all I can do.
I went to a company that programs keys, they looked into it for about 30 minutes and said reprogramming the keys wasn't the solution and that it's something electrical.
I am going to try replacing the smart antenna and see if that helps. I replaced the trunk control module and that did not change anything.
chikn
May 20, 2013 09:46 AM
dandianne
Apr 30, 2011 07:03 PM
LasVegasAccent
Jan 13, 2011 04:15 PM
jspowell99
Jun 3, 2008 05:17 AM
nygiantsfan012
Feb 8, 2008 07:40 PM
