ABS and Traction lights w No Codes
Old Jan 11, 2024 | 02:56 PM
smachado's Avatar
Default ABS and Traction lights w No Codes
Hello,
I have a 2017 Elantra SE. It is presenting an ABS and Traction light on the dash as of this am. There are not OBDII codes either. Also, nothing has changed recently.
Thoughts?
Thanks,
Scott
Old Jan 13, 2024 | 02:49 PM
smachado's Avatar
Hello,
For any that come here to review a resolution, I had a local shop review this with their electronics. It was determined to be a LF ABS sensor. I will be replacing this myself vs via the shop due to crazy ~$500.00 price. I will attempt to update here upon completion.
Thanks,
Scott
Old Jan 13, 2024 | 03:46 PM
Before replacing a possibly good part, suggest you take a look at the sensor and see if it is loose or dirty both of which could produce the problem you saw..
Old Jan 30, 2024 | 05:20 PM
smachado's Avatar
Hello,
Brief update for the benefit of completing this activity.
The first replacement part seems not to have addressed the issue. Lights (ABS and Traction) still on and ABS does not work.
Purchase replacement and have not been able to install yet.
Will post more upon installation and testing completion.
Thanks,
Scott
Terry Godsey
Feb 25, 2021 04:22 AM
linda4940
Apr 23, 2020 01:05 PM
Dustin Corbin
Nov 20, 2014 04:29 AM
Ladydi
Aug 6, 2010 09:28 PM
