2000 Accent piston removal
Old Nov 20, 2017 | 03:39 AM
Bill W's Avatar
Default 2000 Accent piston removal
Hi, would anyone know if it's possible to remove the pistons from a 2000 Accent by removing the sump only with the engine still in the car and replace pistons with new rings the same way?
Old Nov 20, 2017 | 09:05 PM
avisitor's Avatar
I have never done such a thing.
And to be more precise, I watched as someone else was doing it
It was always take engine out, take the head off and flip engine
Then remove the oil, pan, sump, then crank caps and pistons
I would guess it might be possible
But, it is an interference engine
Don't want the piston to accidentally hit those valves
And those caps on the crank are on tight
You would think that once you got the nuts off that the caps would just fall out
Anyway, I wish you luck
Old Nov 20, 2017 | 09:38 PM
Bill W's Avatar
Yeah a bit rough I know. Car is old and 230,000k's on clock. Has been overheated at some stage and the top end repaired. Rings have gone soft and uses a little oil. I thought if it was possible it might be a quick way to restore the engine to some health. Probably better look at swapping motor out. But hey, someone may have given it a go.
Old Dec 23, 2017 | 10:23 PM
Bill W's Avatar
Still interested if anyone has tried this
pjssae
Mar 30, 2011 06:31 PM
Racenut69
Jun 5, 2010 01:23 PM
squeakin
Oct 11, 2008 11:00 AM
justjoshin531
Mar 23, 2007 12:08 PM
olboggy
Feb 2, 2006 11:45 AM
