2001 sonata misfire cyl. #6 p0306
Old Jun 10, 2007 | 10:12 PM
finsfan's Avatar
Default 2001 sonata misfire cyl. #6 p0306
Hi, Ihave a 2001 Sonata, had trouble starting it, would turn over but would not start.came back later started up.went to autozone to have it scanned.they said the code was p0306 misfire cylinder #6 has anybody had a similar problem,is it plugs plugwires coil .fuel injector?if anyone has an idea i sure would like some input.thanks finfan.
Old Jun 12, 2007 | 05:16 PM
lighthouse1's Avatar
Default RE: 2001 sonata misfire cyl. #6 p0306
most likely its the plug and/or wire- depending on milage they may be due for replacement or past due cyclinder 2,4,6 is out front and easy to do - but back is more work - - take off engine cover -4 bolts and check # 6 -its one closest to coil - wire may have mark were fire jumping -- I would change all plugs and wires - if # 6 is bad
ramirez32385
May 3, 2014 02:51 PM
Snab_Nacl
Oct 4, 2011 03:06 PM
inyourface1650
Aug 23, 2011 12:06 AM
jim tjernlund
Aug 26, 2009 07:37 AM
spf150
Feb 11, 2007 03:43 PM
