2004 Sonata, temp fan not working
Hey all,
So I have a 2004 Sonata V6 (yeah, I know, time to get a new car ) and around the end of March started having issues with the heat/ac. The fan will only blow on fan setting #2 and either the floor or defroster. Just about everything I read said to check the fuses and the blower motor resistor. Fuses are fine, so I went to AutoZone to get another resistor and popped it in. Same problem, only now the fan only works on setting #4, the highest one, and only on the cabin setting. Is this a case of needing a Hyundai manufactured resistor, or having the wrong problem? I know I could possibly have blown a fuse changing them out, but is there anything else that could be the culprit? Has anyone else had this problem with an aftermarket resistor? Any thoughts at all would be a big help.
Thanks!
Thanks!
anita
04-27-2009 07:18 AM
rfairorth66
10-26-2008 02:25 PM
