2005 Santa Fe
Old Feb 13, 2010 | 09:09 AM
pocahontas1960's Avatar
Default 2005 Santa Fe
My ABS,TCS and brake lights come on at about 65 miles and he all the time and only go off when engine is shut off. I had new brakes put on and nothing change, what can be the problem?
Old Feb 13, 2010 | 09:12 AM
Does your cruise control work?
There is a recall for the brake light switch on the brake pedal. It controls not just the brake lights but the TCS, ABS and cruise control. Take it to a dealer for a free replacement. Tell them you are bringing it in for the brake light switch recall.
Old Feb 13, 2010 | 09:14 AM
Old Feb 14, 2010 | 05:01 PM
yes my cruise works but it has shut off in the past for no reason. Thank you so much. I looked for any recalls but didnt see this one.
Old Mar 6, 2010 | 08:33 PM
Wrong application !!
Campaign 092 does not apply to 2005 model or 2006 (SM) , 2007 (CM) is applicable.
I would be more concerned with a loose/cracked tone ring at the front axles.... scan for codes first. and not at Auto Zone, need HI-SCAN or GDS to access them module for code(s) -- dealership --
madmongodog
May 25, 2010 06:59 PM
joybaba
Apr 6, 2009 05:37 AM
Dalem
Sep 11, 2008 10:11 PM
DeNobregaInteriors
Mar 14, 2008 11:08 PM
75kaine
Nov 8, 2006 08:17 PM
