2013 elantra blower and a/c only work when fan speedbetween three and 4.
Old Jul 17, 2018 | 10:21 PM
Cbyrd95's Avatar
Default 2013 elantra blower and a/c only work when fan speedbetween three and 4.
Here is a weird one for the guru out there. The fan and a/c only work when in a certain position between three and 4 (4 highest). Changed blower resistor same issue. Changed blower same issue. Even bought and changed entire control panel from a salvage yard and same issue. Ideas welcome!!!
Old Jul 18, 2018 | 03:15 PM
This is what I would try,
You will need a test light or voltmeter to do this,
Remove enough to get access to the blower switch.
One of the leads should be power coming in , key on.
Usually there is a terminal for each speed on the switch.
If you have power coming in, which is there since the other speeds work, check each connection on the switch for power in each speed position.
If you find two positions that lack power, the switch is defective.
Can you do that? Let us know how you make out with this, thanks.
renfrance
Mar 26, 2020 12:14 PM
Cbyrd95
Jul 19, 2018 07:56 PM
Terry G Ravary
Dec 15, 2017 06:28 PM
copydoc351
Dec 2, 2010 08:36 AM
desarabme
Mar 6, 2006 03:25 PM
