Ac blower motor speed at less than full
Old Nov 29, 2018 | 11:15 PM
Hyper H 2012's Avatar
Default Ac blower motor speed at less than full
2012 Santa Fe v6
blower motor only works at full speed.
changed resistor and checked it with ignition on but engine not running all speeds of blower worked.
started engine and blower would only work on full speed.
The BCU body control unit controls input to many thing related to blower.
Could this be a programming software problem?
Old Nov 30, 2018 | 03:15 PM
If the required setting is more than a few degrees different from present, in vehicle temp, and the system is on automatic , it will blow hi speed until it reaches the desired setting. What does it do if you lower the desired setting all the way down?
Old Nov 3, 2019 | 07:04 AM
Rod84's Avatar
I have the same problem in my 2012 Santa Fe. The temperature control is not automatic and the blower only operates at full speed when on. I have already replaced the "resistor" which is really some sort of semiconductor device.
Any suggestions?
Thanks
mmsh81
Jun 7, 2019 08:11 PM
Jpd304
Jul 29, 2017 10:36 PM
riebe
Jul 23, 2012 02:10 PM
golddestiny357
Oct 14, 2011 06:01 PM
copydoc351
Dec 2, 2010 08:36 AM
