CAR WONT START AT GAS STATION
Old Apr 23, 2007 | 12:59 PM
SC21183's Avatar
Default CAR WONT START AT GAS STATION
I have a 2004 Santa fe, and for the past two months, when I get gas only, the car will not start, to start I need to rev the engine and jerk the truck into drive and move a little and then jerk it back into park and continue reving the engine. Approx. 1 minute later she idles and I can turn off and on and everything is normal. Never have trouble starting anywhere but the gas station. Hyundai suggested, dry gas, gas treatment, this proved negative.
Old Apr 23, 2007 | 01:16 PM
Default RE: CAR WONT START AT GAS STATION
Are you overfilling it? Continuing to pump after the nozzle shuts off can overfill the tank and contaminate the Evap/Charcoal canister.
Old Oct 27, 2007 | 04:35 PM
budhayes3's Avatar
Hi, newbie here...I just joined this forum in an attempt to find any info on this same exact problem that my father in-law is having with his 04 Santa Fe (opprox 40k on the odo). It will crank but not start after fueling, no check engine lt, no codes stored in computer, and the dealer has no clue.
Old Oct 30, 2007 | 01:17 PM
HYUNDAI35's Avatar
Either a fuel cut valve part # 31190-38000 or a fuel vent valve- part # 31180-26300 is sticking. Have your dealer contact the Hyundai Techline who will probably approve changing both.... they are only about $20.00 each.
Old Oct 30, 2007 | 08:06 PM
budhayes3's Avatar
Thanks for the reply After a little research, I found someone else who had the same problem and it turned out to be the purge valve sticking open. I mentioned it to my father-in-law and he brought it in to Hyundai, and when they checked it, sure enough it was stuck open, dumping fuel into the intake while upon fill up. Thanks again
jose_santiago70
Aug 12, 2012 08:55 PM
ksojerio
Apr 30, 2012 10:22 AM
vargasgw
Aug 23, 2011 12:16 AM
kingofkingsvi
Dec 2, 2008 03:54 PM
legsmail
Apr 26, 2007 03:32 PM
