fuel system
Old Aug 30, 2008 | 07:41 PM
thorntonite's Avatar
Default fuel system
I am working on a 2002 Accent GL hatchback 1.6L engine. What is happening is: when fueling, gasoline comes back through both the filler neck and the vent. This happens regardless of the tank's fuel level, and within a few seconds of pumping in the fuel. The tank can be eventually filled by pumping fuel in very slowly. Visual inspection fails to discover dents, kinks or any other damage to the fuel filler or vent system. Shortly before this problem developed the check engine light went on and gave a Po442 code, which indicates an evaporative emission system fault. I suspect these are connected in some way, but am not sure where to begin. Given the costs of parts, esp the evap canister, I'd like to get the repair right the first time. Has anyone heard of this problem and its resolution. Even "old time" merchanics are stumped on this one. All help greatly appreciated
Old Aug 30, 2008 | 08:12 PM
Default RE: fuel system
It's probably a problem with a clogged charcoal canister or the vent tubes. The P0442 confirms that. Get a mechanic to check into the charcoal system and gas tank vent system.
BobbyBomber
Aug 26, 2012 04:26 PM
weavejd
Aug 26, 2010 08:39 PM
BrawnyMan
Oct 20, 2009 01:42 PM
sjfarbs
Sep 19, 2008 10:45 AM
ArtZPACarGal711
Mar 22, 2007 02:38 PM
