hyundai elentra 1997 big problem
Old Mar 24, 2006 | 07:32 PM
saiofa666's Avatar
Default hyundai elentra 1997 big problem
my car had a problem before that it's using too much gas and bringing a black smoke from the exhaust and i already changed fuel bumper, air filter, spark plugs, gas filter and adjusted the air/fuel ratio.... the car became much more better and became faster and not making any stupidity anymore....
NOW the car is bringing black smoke and then it ends with a white smoke and its draining oil everytime i look on the oil scale it becomes less and it just makes that when the rpm is on 5 or more and when the a/c is working it moves too slow
can somebody help me and my car cause i love that car so much
Old Mar 26, 2006 | 02:28 PM
duke's Avatar
Default RE: hyundai elentra 1997 big problem
any mods done to the engine ??
what is the odometer reading ???
Old Mar 28, 2006 | 04:17 PM
saiofa666's Avatar
no mods done to the car everything is original except a K&N filter
and the odometer is reading 145000 kilometers
Old Mar 28, 2006 | 06:19 PM
flave1's Avatar
if i were you the first thing i would do if its smoking is check the compression on all the cylinders coz it sounds like the piston rings are shot especialy if you are low on power too.[&:]
Old Mar 29, 2006 | 07:09 PM
poacher's Avatar
Flave has a really good point there. Do you burn alot of oil between changes? If you do can you see any leaks?
Old Apr 9, 2006 | 08:07 AM
saiofa666's Avatar
yes it is burning too much oil and i can see when the rpm just reach 5 ok and the black both with each other.. and yes when i checked the car there was so leaking but not to the extent to lose half a kilo of oil in 1 week and it is running low power but yesterday i tried the car and the max speed i got was 190 something like that i dont know really what is that problem......
Old Apr 10, 2006 | 04:15 PM
flave1's Avatar
ok from what i can gather from your broken english it may well be a mixture of worn engine and leaks causing the problem of excess oil consumption. you should definately get your engine compression tested. cos it sounds like worn piston rings in my opinion.
Old Apr 11, 2006 | 11:43 AM
saiofa666's Avatar
sorry for my writing it had alot of mistakes cause i wrote the reply when i just woke up lool, i will check the compression of the engine before i check the pistons ... thanks alot flave
Old Apr 11, 2006 | 10:32 PM
gadgetman's Avatar
If it's blowing black smoke i'd check the coolant temp sensor. It could be bad and telling the engine it's real cold out . Is the ck engine light on?
Old Apr 12, 2006 | 09:35 PM
Brant's Avatar
Blowing smoke?? Could be a number of things, worn piston rings, worn valve guide seals. Might be that the engine needs some TLC and a good overall.
Good Luck,
Brant
Confused975
Sep 30, 2008 04:32 AM
shooter4n45
Oct 28, 2007 11:30 AM
ctstar2000
Aug 28, 2007 06:08 PM
prexpo27
Jul 20, 2007 08:32 PM
HyundaiortheHighway
May 6, 2005 12:10 AM
