Ignition not starting and ECU not recognized
Old Feb 13, 2025 | 09:23 AM
pcarrell1's Avatar
Default Ignition not starting and ECU not recognized
I have a 2012 Sante Fe Limited with the 6 cylinder. The car was involved in a light front end collision but it did not set off any of the air bags. I can't get the car operable again and could use some help. When checking with a tester there is no power going to the 10 amp ignition fuse in the upper left corner fuse box inside the car. All of the other relays and fuses check out good under the hood and inside the car. When I turn the key to start nothing happens. I do hear a lot of relay clicking going on under the dash but I am having a hard time locating what it is. The dash lights randomly click on and off as well when key is on. I can't get my code scanner to recognize the ECU. I have changed the ignition switch, brake light switch, and neutral position switch with OEM parts. I have also checked all relay and fuses in both fuse boxes to make sure they are good. Any help or suggestions would be greatly appreciated as I have ran out of things to try. Thank you and have a great day!
Hawkiwc
Jun 18, 2022 08:14 PM
Hawkiwc
Jun 18, 2022 04:35 PM
David Snyder
Jan 13, 2022 03:22 PM
TraderVick
Feb 7, 2020 11:08 PM
rodneez
Mar 23, 2013 11:19 AM
