lets try this
So what do you mean by "computer"? Do you have a hand held scanner? Or a device to connect it to a PC. Why are you connecting it? Are you sure "information" doesn't mean information on a trouble code which is not present? Try giving us more information, we're not Kresslin the Magnificent here.
Like I said, you're leaving out too much information. For example, if I knew what year and model car you have, I could tell you if you have the "CAN" protocol for ODB II devices. If your scanner can't see "CAN" then it's useless for many years. Other years have ODB I standard, which is a different animal completely.
But since you are skimpy with the info, it's really hard to give you a good answer.
