No Blue LED High Beam on Cluster
Hello, I just joined to see if anyone can help with a issue I'm having with my 06 Santa Fe 2.7. The is no Blue LED lighting (LED soldered to circuit board) when I put on the high beams all lights in the cluster are working except this one.
I have replaced the cluster with one from the wreckers and still no joy. I managed to find on the net a picture of the fuse box and wondering also if anyone can tell me what these relays are for numbered 1>5.
See Attached
Relays numbered
See Attached
Relays numbered
Fixed_Found the Problem.
I thought I'd share my fix to the solution of No High Beam Indication on cluster.
After obtaining the schematics for the vehicle to which there are 3 scenarios to consider the first does the vehicle have auto sensor for lights,,,2 does the vehicle have DTRL day time running lights? 3 are the lights operated manually only?
My car has DTRL determined by contacting my local Hyundai dealer and running the VIN. That being said I was like well I didn't know that as the vehicle was purchased used so I looked over the schematics for the 2.7Ltr Santa Fe with DTRL traced things back to what I want to share with the forum,,,,the pictures speak for them-self. After locating where the DTRL sender was located I proceeded to remove the battery and battery holder only to see this black tube like thing which had a 10mm nut securing it, after removing the black tube I could see the DTRL unit.
To my amazement look what I found,,,,,,, it had disconnected from the socket.
Maybe this can help someone one day.
PS I have the schematics for all 3 versions if needed send me an Notification.
See attached pictures.
First look under the hood.
Removal of battery and holder.
Removal of black air tube 10mm nut holding it to L fender.
DTRL module plug had fallen off.
