Oil Light On
Old Aug 9, 2021 | 11:11 PM
Lori's Avatar
Default Oil Light On
My oil light came on did an oil change went off for a bit then came back on. Hooked it to a code a reader thinking it might be one of the sensors nothing popped up. Could it be my oil pump??
Old Aug 10, 2021 | 07:28 AM
Usually ,,,,,,,,,,,,an oil pressure sending unit determines if the light stays on or goes off depending on the oil pressure itself.
If you are not hearing bad noises from the engine , there is a good possibility only the oil pressure sensor or the wiring may have a problem. What is usually done is to connect a gauge to the location where the sending unit is located and oil pressure verified. If all is ok there, good chance the sending unit is defective..
throwinrocks
Nov 26, 2021 05:37 AM
Lori
Aug 9, 2021 11:11 PM
Joe G
Feb 27, 2021 08:42 AM
Rhanck
Dec 13, 2011 06:19 AM
mitchkam1
Apr 20, 2010 10:21 PM
